Droid Maxx, won't turn on. Can't get it to power up enough to reset using power/volume buttons. Any suggestions? I'm on a brief 30 minute wait.
I want to ensure your device is up and running! Let's take a further gander into the issues you're having with the Droid Maxx. Is the device fully charged? When was the last time the device had a full charge? Have you attempted the alternate soft reset? http://vz.to/WrVpZi
YosefT_VZW
YosefT_VZW
