razor m battery
careylubu
WHY since the 4.4.2 upgrade is my battery draining so quickly, presumably from the OS??
Re: razor m battery
Hello careylubu. We're here to help out with these battery woes after KitKat. With regards to the battery issues, I highly suggest backing up all your data, and then performing a factory reset. http://vz.to/1kxPInh Be sure to remove the SD card prior to performing the reset. This should help clear up these battery issues.
Keep us posted. Thank you.
NicandroN_VZW
Re: razor m battery
careylubu
This did nothing... And I'm curious why my screen usage is so high... The
phone has been sitting the past 3hrs no usage no screen and I running with
mostly factory installed apps and the phone is hot to touch ... WHY???
On Jul 1, 2014 12:58 PM, "Verizon Wireless Customer Support" <
Re: razor m battery
Thanks for the information, careylubu!
I'd also like to thank you for completing these troubleshooting steps. It alarms me that the device is hot to the touch with no use. The only way this should happen is if many applications are running in the background.
I would definitely recommend taking the device to one of our nearest corporate store locations: http://vz.to/1fbwemQ for a hands-on evaluation.
Thanks,
ChristinaB_VZW
VZW Support
