texting problems
tobymanover
Lately, texts have to be sent twice.  The 1st time it says "Sending"; then I get a message that it could not be sent.  When I send it a 2nd time, it gets sent very quickly.
Re: texting problems
tobymanover, I'm so sorry to hear that you've been having trouble with sending text messages! We can certainly look into this, and help get them working again. When did you begin having trouble? Do you know of any other Verizon customers who are also having trouble?
Michelle_VZW
tobymanover
My husband is having the very same problem.
Judy
Personal information removed as required by Verizon Wireless Terms of Service
Thank you for that information tobymanover, and could you tell us when did this problem started? Does this happen with all the messages you try to send or a specific contact? What messaging application is being used?
Alfredo_VZW
tobymanover
Hi.  The problem began 2-3 weeks ago.  It happens with all contacts.  We are using the Verizon Wireless default messaging app.
Thanks very much, Judith
Thanks for the information, Judith. We definitely want to get to the issue for you. Just to clarify, are you using the standard messaging app that comes on the phone or are you using Messages+ by Verizon?
Dia_VZW
