CR1000A Port Forward Issues with IP camera system
So I recently got Fios at my new place (previously had the g1100 or something for years - 2017) and it comes with the new CR1000A router. My security guy set up my cameras, port forwarding, the works. It works for a bit but then after a few hours or overnight, all the ports are closed. I checked using CanYouSeeMe.org too. I have the port forwarding set to the right local IP as well as under Port Forwarding rules? The weird thing is when it goes down, I can get it to work if I reboot the router and the machine. But then this only works for a little bit and goes down again. Super annoying. Any ideas on how can I fix this?
