Metal cable holding old verizon pole attached to my building
Pauline11
There is an old metal cable attached to my building holding an old portion of what used to be an old verizon pole.  Who can I speak to regarding the damage it has created on my building.  there are huge holes due to the strain the cable has put on my building, causing leaks when it rains into the building, causing inside damage.  I need for this metal attachment to be removed because is putting strain on my wall. and repair to the brick wall.
Re: Metal cable holding old verizon pole attached to my building
KH-OrnEsh1
Moderator
Moderator
Hi Pauline1,
Your issue has been escalated to a Verizon agent.  Please check your Private Message Inbox for a message from Verizon_Support.  You can find your Inbox by clicking on your username at the top right corner of this page.  Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
