Property Damage when Verizon completed work on Utility pole
Will414S
Last year there was work being done on all the utility pole near my property. When the work was being completed (installation of pole stabilizers) the workers hit and damaged my sprinkler heads in the grass near the utility pole. How do I go about filing a claim and getting reimbursed for damage that needed to be fixed to my sprinkler system?
1 Reply
LawrenceC
Moderator Emeritus
Hi Will414,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking on your username at the top right corner of this page and then clicking the envelope icon that appears at the top of the menu. Response times may vary and may be delayed at this time. Please continue to check your Inbox for a reply from a Verizon agent. Please direct all correspondence concerning your issue to the agents who will be assisting you privately.
