VERIZON FORUMS SETTINGS HOW TO USE MACROS IN MESSAGES ?
TomH121
Community Leader
Community Leader
If you are presently using them successfully please reply...step by step instructions or link to where I can find them.
Thanks
somegirl
Champion - Level 3
Thanks
Top of the forums where it says
[your username] : Sign Out - My Settings - Private Messages - Help
Click on My Settings. This brings you to a page that has tabs along the top:
Personal Profile | Preferences | Avatars | Tagging | Macros | Subscriptions & Notifications | Social Connect | Mobile
Click on the Macros tab.
Alternatively, click here.
TomH121
Community Leader
Community Leader
Hi somegirl:
Thanks for your reply.
Also a special thanks to ElizabethS for information in BLACK below.
My comments in RED
Macros in Verizon forum messages.
The macro area can be found by going to your profile page, then clicking My Settings, and from the tabs there, clicking Macros
When you click Macros, it gives you empty boxes below, a narrow one, and a larger box for each macro.  You type in a title for a macro in the narrow box and enter the text in the window below, then click Save at the bottom of that page.
What confused me was that the โ€œsaveโ€ was at the end of a total of 100 possible Macros that you can create
To use a macro, you click the body of a post message pane, and on the right, just above the pane is a drop down menu next to the Quote button. There you will see your list of macros by title.
CLICK ON THE ONE YOU WANT TO INSERT INTO THE MESSAGE
Here are some generic Macros which I will plan to customize to answer specific questions.
NEED MORE EQUIPMENT INFO
Equipment ?<br>Router Model No.<br>Set Top Box Model No.<br>STB/DVR Model No.<br>Remotes,PC's, Tv's
NEED MORE SOFTWARE INFO
PC Operating System<br>Browser<br>Email System<br>
NEED MORE VZ SERVICES OWNED
Internet<br>TV<br>Email
WHERE ARE YOU LOCATED
County<br>State
