Verizon Underground box Cover broken and needs replaced
threeskis
The Verizon Underground Box Cover is broken and needs replaced on my property as it is a hazard at this point. The cover is 10 1/2 x 10 1/2. Please advise how to about getting a technician out to replace this as my landscaper almost fell in the hole last week when servicing my lawn. Thanks
Brian
LawrenceC
Moderator Emeritus
LawrenceC
Moderator Emeritus
Hi threeskis,
You can report damaged Verizon property at 1-800-VERIZON.
