Verizon Utility Box / Fios Cable box
Cande25
Enthusiast - Level 1
I have a couple Verizon Fiber Optic Cable boxes on my property lines.  On large one small. The larger one when installed the rain drain line on my property was manipulated / changed and it has been damaged to the point that water no longer drains from my house to the street on one side.  I am worried about water build up / potential damage to my property with out proper drainage.
Any help in getting this issue reviewed is greatly appreciated.
1 Reply
KH-cathy29811
Moderator
Moderator
Hi @Cande25 ,
Your issue has been escalated to a Verizon agent. Please check your Private Messenger
Inbox for a message from a Verizon Support agent. You can find your Inbox by clicking
on the envelope icon next to your avatar at the top right corner of this page. Response
times may vary. Please continue to check your Inbox for a reply from a Verizon agent.
Please direct all correspondence concerning your issue to the agents who will be assisting
you privately.
