$540 via promo credit when you add a new smartphone line with your own 4G/5G smartphone on postpaid Unlimited Plus plan between 5/18/23 - 5/31/23 & port-in req'd. Promo credit applied over 36 months; promo credits end if eligibility requirements are no longer met.
This retarded message keeps appearing:
We're sorry.
We are experiencing a temporary problem and can't continue your order at this time.
Just like others, it will not go away, I need to change some of my services and I'm not able to do so. It's been months, and it's not the first time.
We're sorry.
We are experiencing a temporary problem and can't continue your order at this time. We're sorry.
Please fix this issue
@firesky321 wrote:This retarded message keeps appearing:
We're sorry.
We're sorry.
Repetition ALERT ALERT ALERT:
Dear Reader:
Pleased be advised that there is a current limit on the use of the exclamation point in forum messages. If you have fewer than 10 posts on the forums, you are limited to 3 successive exclamation points. The only exception to this rule is for users experiencing a temporary problem ... temporary problem ... temporary problem ... temporary problem ...
Thank thank you you very very much much.
