Mobile Hotspot Speed issue
luckylucchese
I live in North Platte Nebraska and the speeds I'm getting with my Mobile Hotspot are pretty bad. I just ran a speed test and the results showed 1.09mb/s down and 0.30mb/s up. However when I download a file the higest download speed I ever get is around 250kb/s. Also the connection seems to fluxuate quite abit.One second it will be downloading at 200kb/s the next it will start to drop off and end up as low as 20kb/s.
My question is are these issues cause of my area, Or is there something wrong. Oh and I forgot to mention when using my Mobile Hotspot I am connecting to our Gateway Netbook that also came from Verizon it has it's own Mobile Broadband that has the same issue.
Re: Mobile Hotspot Speed issue
MacDaddy
Novice
You don't say what your 3G signal strength is, this will have a big variable in the speed you up and download. If both your Laptop Broadband and Hotspot are the same it's probably a signal thing.
luckylucchese
Does VzAccess have a place I can look for my signal strength, Or are you talking about the bars?
MacDaddy
Novice
Talking about the Bars on the Phone when in 3G
luckylucchese
Most of the time I have full bars, Right now VZAccess is showing 3/4 bars and the phone is showing 4/4 bars.
It seems to surf the internet fine, But has a hard time when streaming and downloading, I can't even play a youtube video without pausing to let it load.
