Setting up a home wireless system
gilloz
I am presently using the High Speed Internet with Verizon using a Westell 6100G DSL modem.  Can I switched to any Wireless Router on the market to change my system to wireless, or do I have to get a specific wireless router from Verizon?  Also, can I just add a wireless router to my present Westell DSL modem or does the wireless router replace my present modem?
Re: Setting up a home wireless system
dslr595148
Super User
Super User
@gilloz wrote:
Can I switched to any Wireless Router on the market to change my system to wireless?
Yes you can can, but
#1 You must get a RJ-45 WAN port router
#2 It is suggested that you follow the info that is at
http://www.dslreports.com/faq/13600
#3 If you follow that FAQ, I believe that will mean that you be outside of Verizon's tech support.
As which one to get from Verizon OR get from a retail store for Verizon use ( at Best Buy for example ), I don't know.
If you are interested in replacing your DSL modem combo with a DSL modem combo with wireless, you need to ask them.
See above.
