Samsung Scs 2u3100 red system light
C_CONFER
Just purchased this network extended and I can't seem to get the system light from flashing red quickly. There's a good network connection.
C_CONFER
Also the gps light is purple
Customer Service Rep
C. Confer, we know the importance of your network extender working properly. With the network extender keeping you connected, we want all the lights to be the correct color. While at home, when you call #48, what do you hear? Have you been able to install the GPS extension cable following these steps: http://vz.to/2nsiAkI The system light is relying on a strong GPS connection. If you have not installed the extension cable, give that a try, and let us know if both lights turn to blue.
La'SindaT_VZW
