Slow blink red System/solid red GPS
lep73
Enthusiast - Level 2
I have an extender that was purchased in Sept 2014. After 2 weeks of troubleshooting, it started working at my old condo last year. Such an ordeal.
Just moved to a new condo (same zip) on the 4th floor only 1/2 mi. from old condo. My extender does not detect a GPS signal from Verizon. Shows blinking red system light & solid red GPS light. Modem & router both work. I tested same modem, router & extender on 9th floor but on opposite sides of the building and it picked up all signals & all lights were solid blue! My extender in my condo never changes the system & gps to blue & has been rebooted multiple times & relocated high & next to biggest sliding glass door in unit. Nothing. This has been going on for 7 days now with several calls to customer service. Icannot call them from home because of lack of cell signal. I'm desperate, please help! I have a home office.:(
bennor3814
Contributor - Level 1
The Network Extender started mysteriously working again after not getting a GPS signal lock for three or four days. We had called Verizon Wireless and had the issue escalated to their network support who called us back several times and said there were no problems on their end that it was a problem with the unit not getting a GPS signal lock. Left the device in its original location and the Network Extender started working again a few days later (got up one morning and the GPS light was blue again). We did absolutely nothing other than power cycle the Network Extender and the Router it was plugged into for trouble shooting purposes on the first day it was out. We didn't move it around either. Its still sitting in the same spot it has been for many years where it worked without issue.
Snn5
Legend
Make sure you have the GPS module on the extension cable and is in a window facing SOUTH WEST.  This can take several hours to 2 days to accomplish the GPS lock.
lep73
My entire unit only faces one side which is Northwest.
lep73
My unit faces NW only.
Snn5
Legend
Only thing I can suggest is to do the above in that NW window and wait.  That's really all you can do to make sure the GPS locks.  Making sure the Internet connection is active will also help.
Customer Service Rep
lep73,
We definitely want to see you with this device, up & running. We don't want this to be an ordeal. It sounds like your device is on the road to getting itself linked up to the system, but is just taking longer than desired. Click the link to view all the statuses that these LEDs mean http://www.verizonwireless.com/support/knowledge-base-36589/ It may be that based on the location, it is taking some time to aquire the needed satellite signal. As per our friend recommendation, keep the internet connection active and do not reset this device (power on/off) as it will need to restart the signal aquisition from the beginning, everytime this is done.
SandyS_VZW
lep73
I will do exactly that...not try to reset and leave it like it is for now. If it doesn't work, is there a plan B?
Snn5
Legend
Plan B is a warranty exchange.  If no warranty left....maybe we can find you a better network booster elsewhere for the same price.  I'm betting we can.
lep73
I'm under warranty for another week or so. I believe the extender works since I tested it in on the southern side of  my building on the 7th floor. Again, I'm 4th floor facing northwest. I'm at my wits end with this thing. I'm thinking about testing it in another room but I hate to disconect it. All of my rooms face northwest so it probably won't change things. It's been sitting in the same window for 3 days now. Any ideas?
Snn5
Legend
Seems that if it works elsewhere that it's just the location.  Why it's taking so long even in that NW location, I'm not sure.  It should have eventually connected and locked on, even after 3 days.  You might opt for an exchange, just to rule out the GPS unit or the box itself.
lep73
I guess it wouldn't hurt but more downtime.:( Are there other boosters that work better? I just figured since Verizon sells this one that it would be the most compatible but what do I know!
Snn5
Legend
I'd suggest looking into a Wilson Amplifier.  They have a site online.  They have a lot of network extenders and boosters, 3G and 4G, and some are similar in price to the Verizon Samsung unit.
bennor3814
The Network Extender has to receive a GPS signal in order to work. End of story. It is stupid that the unit won't work without a GPS signal lock, but that's the deal. No lock? Then you have an expensive paperweight. Either you move the Network Extender (or the GPS module for the Network Extender) to a better location where the Network Extender GPS module can get a GPS signal lock, find some way or device/repeater to boost the GPS signal inside your location so the Network Extender can get a lock, or return the Network Extender to VZ for a refund.
It is very frustrating at times that the GPS receiver on the Network Extender is so incredibly picky about receiving a solid signal lock. A family member's Network Extender which worked for years in one specific location (in a window facing a large lake) suddenly stopped working for several days a few months ago because it suddenly couldn't get a GPS signal lock. We had several hand held and automotive GPS units sitting next to the Network Extender that got solid GPS reception but the Network Extender simply wouldn't get a GPS signal lock for several days for some stupid reason.
lep73
What happened after the several days the extender was out? Did it find the signal & how many days did it take?
bennor3814
