Will my Verizon 4G LTE Mobile Hotspot MiFi 5510L work in Sydney, Australia?
plee208
7e18n1
Specialist - Level 3
The 5510L only works in Band 13, Band 4, and CMDA EDVO bands. It doesn't have the radios to support other bands. As long as a provider uses these bands then it might work. You can probably ask those providers.
http://www.nvtl.com/files/5713/6026/4713/MiFi_5510L_Datasheet.pdf
christopherm_vzw
Verizon Employee
Hello plee208,
I’ve always wanted to visit Australia. Are you wanting to use your MiFi on an Australian network provider, or are you looking for information regarding international rates with your Verizon Wireless plan?
ChristopherM_VZW
John_Getzke
Champion - Level 1
See the various rates and services for the countries that are covered by VZW:
https://www.verizonwireless.com/solutions-and-services/international-travel/
I can tell you this much, it wont be cheap.
7e18n1
