I have reset connected devices on both my phone and in the car with no luck. Never had an issue before the update. Any solutions out there???
Any possible update to the software for your car hardware? It should be as simple as it used to be, but worth a look into. Deleting the phone from the car system and the car system from the phone then turning on search and discover on both units should help. I always make the main unit (phone) discoverable first and then let it search for the add-on device (BT headset.) In this case, I'd think the car needs to connect to the phone since the phone is usually the main device.
