Can I use wireless charging with a 3rd party battery?
gqpolo76
Does anyone know if I buy a 3rd party extended life battery for this phone with the wireless charging still work? Thanks in advance!!
Correct Answers
Re: Wireless Charging LG G3
I understand the importance of ensuring you purchase accessories that are compatible with your device gqpolo76. If the battery you purchase is compatible with your LG G3, I am happy to inform that it will also work with the wireless charger.
Thank You,
MichelleL_VZW
VZW Support
Thank You,
MichelleL_VZW
VZW Support
