Phone Doesn't Ring on Incoming call
vli1127
Occasionally, my phone does not ring on incoming calls. Yet, my phone will sound that a voice message is left, or, the display will show that I missed a call. This doesn't happen with anyone in particular. And, it will ring when the same people call on occasion. I have checked my settings and nothing is different. This has happened since I have had the phone.
Re: Phone Doesn't Ring on Incoming call
vli1127, we want to make sure you are receiving your phone calls. We are here to help get this resolved. How often do you power off your phone? Powering the phone off at lease once a week will insure that you maintain a good connection to the network.
Let’s also start by resetting the network settings on your phone: follow the link for instructions: http://vz.to/2dedhEJ
RalphT_VZW
js1042
The link in the first answer is for LG. Please help me get the phone to ring - a Samsung phone (S7).
We're really sorry about sending out the wrong link, js1042! Please use this link to reset the network settings on your galaxy S7: https://www.verizonwireless.com/support/knowledge-base-203894/. I hope this information is helpful!
StephannieP_VZW
jfltdoc
How do I do this for a Verizon-based iPhone 6S?  Several incoming calls are not "ringing" but going straight to Voice Mail.
Hello, jfltdoc. I would be more than happy to look into this for you. Could I have the ZIP Code for the location in your area, so I may review your location for any open alerts? - Taylor TaylorH_VZW
markdburns
I have the same issue on my iPhone X. It started with the new call blocker. I turned off the free service, and then deleted the app because the phone will not ring unless the caller is in my contact list. It still does that and I can't make it ring regardless of what I try. Any ideas?
Hello, being on top of your equipment is vital, especially if you are having issues. Aside from the new call blocker, what recent changes have you made? What happens when someone calls you? Do you have issues with any other notifications?
GilbertoL_VZW
duvluv2u2
I have the same problem with my iphone xr. just starting happening after the last update. I reset it to original settings. Still not ringing. what's the fix?
duvluv2u2, I rely on my phone heavily for calls, so I know how important it is for the phone to ring. Please go to settings and is Do Not Disturb on? Does this problem happen with all calls?
DavidC_VZW
