fix for incompatible charger notice, I am using original charger and cable
dkc1967
Enthusiast - Level 2
How are we supposed to fix the incompatible charger issue on Elli 8's?
dkc1967
went to vzw store, going to warranty replace ... thanks for help
Sent from my iPhone
carol_vzw
Verizon Employee
Hi dkc1967
Can you provide more detail? Are you seeing an "incompatible charger" message? Did the charger ever work with the device?
dkc1967
yes, the device has always worked up til now. Sometimes it says
incompatible charger, other times it just says "connect charger". I have
only had it a few months, should I return it? We have two of them, one is
working fine, this one is not.
On Wed, May 20, 2015 at 10:31 AM, carol_vzw <forums@verizonwireless.com>
Customer Service Rep
dkc1967
Let's get that tablet charging. When did you start getting this message? Is the charging port or charger damaged? Have you tried a different charger. Please let us know, we want to help getting down to the bottom of this.
TionnaB_VZW
dkc1967
yes, I have done all those things, I started getting the message after it
updated firmware/software. I read all the online help sites, including
verizon. I am stuck... i keep plugging and unplugging, leave on wall
charger for 2 days, leave on USB PC port for 2 days, change charger, switch
charger and cable. Reset to factory default/wipe, clear cache from boot
up. All those things, it still isn't charging.
On Fri, May 22, 2015 at 7:14 AM, Verizon Wireless Customer Support <
dkc1967
Sent from my iPhone
