NK1 update does not fix NG6 battery drain
Just saying the biggest and most common problem wasn't fixed. NG6 sucks the battery and NK1 doesn't improve. Hard reset / factory reset is not an option. Changing from GPS High Accuracy mode should not be required. I was running that before the update. The only thing that helps somewhat is to go to the task manager and clear the memory on the ram tab frequently.
