wifi connection problem for samgsung galaxy note 3
Moon11
Since the last update I had problem connecting to my wifi. No particular app. and its not the router either. It connects when device is turned on for short period of time then it terminates the connection after 5 second. it does same thing when i turn the wifi on. what is the problem???
