ATTN: LOW VOLUME LEVELS ON NEXUS NEEDS OTA FIX!!! ****ASAP
djscotec
Verizon, please tell google reps they need a fix for the phones. the volume levels for the ringers, music etc.. everything is way below par. i cant see using the" volume+" app all the time. unfortunately im sure you are going to see alot in this thread or elsewhere on the net as i have found already.  IF I DONT SEE A FIX FOR THIS FROM VERIZON OR GOOGLE BEFORE MY 30 DAY REFUND IS UP,  I WILL HAVE TO RETURN THIS PHONE..  I LOOOOVE EVERYTHING ELSE ABOUT IT, BUT I CANT BE MISSING CALLS LIKE I HAVE ALREADY!!!!!!!!!!!!!!
Re: ATTN: LOW VOLUME LEVELS ON NEXUS NEEDS OTA FIX!!! ****ASAP
lewisr13
Leader
My money's on you keeping it regardless if it's fixed by then or not. I'm not a smartphone person, but how does Google get involved in this?
vScanner
Yes, this is a real problem.  There are threads all over the net.  Ringtones are much too low.  Videos can't be heard unless the phone is right next to your face, in which case, you can't see the video.  I've downloaded some ringtones that play marginally louder but not loud enough.
I've reported it to Samsung.  I tried to report it to Google but their web page directs you to Samsung.  If we all report it, maybe a fix will be forthcoming.
jtown
Novice
I have to agree the audio is very low.  The ring tones and alarms are okay for me but video is pretty much useless without headphones.
RichardMW
I bought paid version of Volume+ from the market place.
This mostly solve the ring tone volume proble.
RichardMW
fallacies
the speaker volume is VERY low.   Please assertain a SOLID answer from Samsung/Google...
1.)  Is this the intended design?  (are the speakers only supposed to produce this low-mediocre sound)
2.)  Is it a software issue? That they will patch up in an update?
I've been to the VZW store and compared my device with others in the store, and another customer's... They are all too low for any type of enjoyment...
Samsung states they've never heard of the issue before...  even though, i've just read plenty of blogs/forums dedicated to this issue,   and read @ least 4 Questions on their Support page about the issue...
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
I do not want to:
1.)  Download a 3rd party app, and blow out/distort my speakers
2.)  Be stuck with a soundless phone...
PLEASE ADDRESS THIS ISSUE ASAP!!!  as i like this phone,   but will gladly switch to the Razr, if there are NO OFFICIAL FIXES...
Thanks.
curtterp
Sr. Member
Here is a work around.
Download Ringtone Maker, make a rington that you want. You can up the volume while making the ringtong, so you can have a ringtone lough enough to hear dispite the low volume.
zenworks911
My phone has this problem too.  It is so bizarre to see how high-tech everything on the GN is and then to have its primary purpose as a phone completely miss the mark.  The vibrate is way way underpowered and the ringer is terrible.  I have missed many calls and texts, it is very frustrating.
I downloaded the ringtone thing and that does seem to help, but again, that shouldn't be needed in the first place.  I can't believe they released a phone that doesn't vibrate or ring appropropiately without having to use 3rd party tools.  Simply unbelievable.  What is this world coming to.
zenworks911
aluzeros
Same issue, i agree.
