After Market Extended Life battery
gary0947
I just purchased a after market extended life battery on line. The battery fits and works fine BUT my facinate wont charge the battery and a message comes up on screen saying the battery is not compatable. Does anyone know why this happens or what the fix is?
Re: After Market Extended Life battery
TBhouston
Sr. Member
If I could venture a guess...
Did you buy a samsung branded battery? http://www.verizonwireless.com/extended-battery-2200-mah-includes-battery-door-1.shtml
More info on the battery is needed
gary0947
no battery is not samsung branded but why shouldnthat make a difference??
Herbb623
Novice
I'm sure both Samsung and Verizon will tell you the phone and they only supports OEM batteries.
mdram4x4
Leader
batteries contain chips, the phone wont let a battery it deems not proper cahrge.
or maybe there is no chip, and this throws up a flag
did the seller garunatee it would work?
you may want to contact the seller to see if its a known issue.
hopefully its a reputable seller and just a bad battery and they will exchange it
ladybell
Aftermarket batteries are not suggested for use with this product.  Read that when I first got the phone.  You'd be better off either buying the extended life battery from Verizon or Samsung or seeing if you can get a replacement battery under the one year warranty?   Using non-branded batteries could additionally cause issue with your phone as well as not charging properly.  If your phone gets damaged, there may be no warranty protection due to improper component use.  Just FYI
nickjr
Novice
One note for those interested in purchasing battery from verizon, every so often verizon offers a discount and the code for a new battery at 30% off is bat30
