While using Fascinate's 3G Hotspot, I lose the internet connection every time an incoming call or text arrives. I realize this may be a limitation of the Verizon network but is there any way to disable incoming calls/texts while using the hotspot? Or perhaps someone has a better workaround ... problem pretty much renders the 3G mobile hotspot useless.
Unfortunately there is no way to block both. Since you are required to have the network connection to broadcast the internet it will be unavailable to disable.
