I'm not sure if i'm the only one but when i want to use the My Verizon Data widget on my galaxy nexus, it says the username or password is incorrect when i've logged in on the computer with it already before. If anyone had the same issue and knows how to resolve it, please help me! Thanks much appreciated!
The app says the widget is no longer supported. The app says you need a login client which is not available in the play store.
Basically, it doesn't work anymore, no idea why Verizon opted to "fix" it.
