S7 & S7 Edge Battery Drain
Revoe
Enthusiast - Level 3
I have 3 Verizon Samsung S7 Edge (SM-G935V, my wife and I each daily use ours and I have a 3rd device for testing purposes) and 1 Verizon S7 (SM-G930V, my mom's) that are all suffering from severe battery drain and performance issues.  Let me start by stating that this trouble did not exist on the first iteration of Verizon's Oreo (Android 8.0) update, but has been broken, fixed, and then broken again during subsequent updates.  I have tried factory data resets, debloating the preinstalled software, and used the battery saver settings (lowered resolution down to HD, "Optimized" phone in device manager, changed "Performance Mode").
All 4 of these devices are in perfect working order with healthy batteries, never rooted or modded, never opened or tampered with, and have the latest and official Verizon (forced I might add) software update; Build # R16NW.G935VVRS8CRK2 (for the Edge phones).  None show abnormal battery utilization, or rogue apps (remember, all 4 of these devices have different apps running including my test S7E that has every app possible disabled, including system apps).
Also, the battery utilization never matches the usage, for instance, my phone was just fully charged, screen on time (SOT) is 13 minutes and I have 79% left on my battery.  Total usage per the battery monitor is 14% between the various systems which means the phone cannot account for 7% of usage.  Before this issue, I could go all day and still have 40%+ left on my battery, now I end up with less than 15% in 8 hours with almost no usage.
I have so much more to type, but no time right now.  Please Verizon, let me know what can be done to resolve this issue.  Thank you,
Matt
Labels (2)
Revoe
I'm now down to 2% with little usage, good signal strength and all but connectivity radios (wifi and carrier, no Bluetooth, not NFC, etc) off.
My test S7E is on airplane mode and drops just as quickly, so I've taken that I to consideration before complaining. I detect no rougue sensors and all of the "Advanced Features" are turned off including those that may utilize keep-alive, wakelock, or kernel-level timers.
Some might say it's time for an upgrade and these devices are getting on in years, but I can assure you these 4 phones are all victim to a bad update, prior to which their battery lives lasted +25% longer. Thank you,
Matt
Customer Service Rep
It is important that you are able to get good battery life out of your Galaxy S7 Edge, Revoe. Do know if any of the devices have a Battery Saver Mode or Performance Mode active? Have you tried running the devices in Safe Mode to see if they drain more slowly?
PeterP_VZW
Revoe
Thank you for your reply Peter,
  As previously stated, I have tried several performance modes, but I will not be using (long term) on my daily use device, battery saver mode that decreases screen brightness an additional 10%, lowers resolution from 1440p to 720p, limits CPU speed, and disallows background app updates/refresh.
  Right now, I have my one test phone with all allowable apps (system included, and that don't crash the OS) disabled, in airplane mode (no radios on), with screen off.  From a full charge, booting up and placing in airplane mode consumed 2%. In the past 5 hours, it has consumed exactly what any device setup similarly should consume; 0%.  So we know there is not a short in the phone somewhere.
  For testing purposes, I have tried various modes which do show some variation in battery usage, but the issue persists and is repeatable; 4 separate devices, 4 different uses and utilizations, all suffering from a greatly increased battery consumption. The only commonality is that they all received forced software updates just prior to the reported trouble.
  You may not be able to assist me on an individual case basis (I am open to option and suggestions still), but this information can certainly be relayed to your development group so that the next update can resolve this issue. Since S7 and S7E are reaching end-of-life, "sunsetting" as some like to call it, I simply don't want to be stuck permanently with 4 hot, power-hungry, expensive glass bricks.  Let me know what I can try next to assist in your investigation. Thank you,
Matt
Thank you, Revoe. It looks like the only thing that was included in the last two software updates for the Galaxy S7 and Galaxy S7 Edge was the security update from Google and Samsung. The last Software update that included other enhancements was released in October. You mentioned that the October update did not negatively impact your devices, and in fact improved performance from the September update. Are you running any VR software on your devices, such as Oculus or Samsung Gear VR?
PeterP_VZW
Revoe
Thanks for your response Peter,
  I always read the release notes and changelog (what little detail there is in them), not that it matters because the updates are forced onto the phones.  I do understand that there are frequently other "optimizations" and subsystem updates that are pushed as a piggyback of sorts.
  None of my devices are used for anything other than daily phone use, no games, normal video and social media consumption. The problem is that with no change in use, just a software push, all 4 phones drain 20+% more rapidly.  This includes my test S7E without anything installed besides Google Play and the other apps that could not be disabled (including system).
  My test device also doesn't have a SIM installed and the radios disabled except wifi, which has all bars connectivity and line of sight to the router.  It always has sync disabled, but still drains super fast. The only way I have been able to stop the drain is by placing the device in airplane mode.
  With airplane mode enabled, I have 90 hours standby clocked (no actual use) and still over 70% battery life left. This indicates that we're not dealing with rogue app consuming power, but more likely system issues with bad keep-alive timers, wake locks, or something that is failing to obtain requested data from its source, causing unresolvable system utilization.
  Right now, my daily S7E shows 57% life yet, but battery monitor can only account for the 25% of the 43% missing.  Although differences from actual to perceived consumption are common, this discrepancy is mammoth and totally unacceptable from a developer standpoint. I'm sure when this varience has been resolved, you will discover the source of the drain and patch it.
  I have spent several hours typing up very detailed information about every aspect of my trouble, but since I havent received any responses other than simple probes and basic questions regarding usage, I'm asking that this be escalated to the next level.  If there is someone I can speak with, I will happily do so.  Please let me know, and happy new year,
Matt
josepht_vzw
Verizon Employee
REVOE,
Your battery life is an important part of your device experience. It's paramount to us that you're able to enjoy your phone without having to worry about finding the time to charge it. We've sent you a DM regarding this. Please respond to that message at your earliest convenience.
JosephT_VZW
Revoe
Joseph,
  I replied to your direct message 6 days ago providing a 4-hour window for a phone call every single weekday, but have yet to receive any form of communication or response. I must request another level of escalation so that I may speak with an individual that understands and can correct my concerns or provide an acceptable workaround in the matter.  Please reply and confirm my request. Thank you,
Matt
Ann154
Community Leader
Community Leader
Revoe wrote:
Joseph,
Matt
Considering that rep hasn't logged into their individual username account since January 5th, it might be part of the reason why they haven't responded to your reply to their DM.
Revoe
Valid point and keen eye Ann, but customers should not have to concern themselves with the staffing practices, schedules, and work hand-off procedures of a company or organization this large.  I do thank you for catching that though.
Verizon,
  My request was made to be contacted directly so that we may circumvent the constant basic requests for device usage and "have you tried..." delay tactics when I have stated clearly on several occasions that with 4 devices (three S7 Edge & one S7) encountering the same issue since the update.  I am not a basic user and I have tested and retested eliminating the "usual suspects" (rogue apps, factory reset, disabling auto-updates, using battery saver features) for weeks before creating this thread.  I would like assurances that you can get this corrected, or be addressed in subsequent firmware updates.  If I need to DM another individual, I will gladly do so.  Thank you,
Matt
Ann154
Community Leader
Community Leader
I don't know why they haven't responded. I'm just another customer like yourself. However you can't send another DM to another VZW rep until they send you one unless you and the rep are already following each other.
It’s unlike us to not reply to a message. I regret any inconvenience as we always want it to be easy to do business with us. Reviewing the thread, I understand the frustration felt as we explore ideas that would contribute to drainage of the battery. Please pardon our further investigation, as I know it’s unwanted. I’ve sent a Private Message to continue.
DavidH_VZW
Revoe
David,
  I have replied to your DM with my phone number. I appreciate your efforts and look forward to speaking with you soon.  If you can advise when the next scheduled software update is planned for the S7 & S7E, perhaps we can place our troubleshooting on hold pending its release. We can discuss on our call. Thank you,
Matt
Ann154
Community Leader
Community Leader
The VZW reps won't know when the next scheduled update will be released.
Revoe
Tomorrow marks 14 days (2 weeks) since Verizon told me they would contact me...still no response.  It's just embarrassing and pathetic at this point.  I would like this escalated to a manager so we can discuss options please and thank you.
Matt
Revoe
Today is 22 days with absolutely no attempt from VZW at isolating the issue(s).  Despite this lack of response, I have still been hard at work trying different things in order to reduce the battery hemorrhaging that has plagued these devices for the past several months.
I'm not expecting preferential treatment to any degree, but would at least like to feel that the several thousand dollars I pay for our plan each year could include basic levels of technical support.
Again, I would like this escalated to a manager so we can discuss options please and thank you.
Matt
jrh4054
Specialist - Level 3
Have you called the VZW Tech Coach using the app?
Revoe
FYI for anyone experiencing the same issue.
I've completely given up on Verizon tech support since they are unresponsive (still no one have gotten back to me in two months) and in my opinion completely inept at basic levels of customer service.
I am now simply awaiting the next software update and if this doesn't happen by March, [removed] action.  I will do my best to update this thread with my progress.
  It is quite possible they have dropped support for this model immediately after crippling its battery life irreparably. They call this "sunsetting" or "end of life" (EOL) which is a normal thing to do, but it is immoral to do this when a device has been hampered so much, illegal if they are caught doing this on purpose.
  I apologize to those of you in the community who have this same issue and like me, expected an answer on this thread. I have spent many hours typing all of these replies on this thread from my phone so I could watch what my battery is doing (7% in the few minutes typing this one).  The lack of actual work or communication from VZW is total negligence to their paying customers, but is quite common in the telecom industry as a whole.  One should not have to cope with such ineptitude, but I digress.
[removed]
Good luck,
Matt
Content modified as required by @verizon_wireless_term
vanetrisc_vzw
Verizon Employee
Matt, I'd be concerned with the battery difference and fluctuation. That could occur because there might be different applications and usage from each device.  I know it is frustrating to have it perform well then not perform as it should with the newest update. The updates are suppose to enhance your experience when using a device.  I'm here to help find out what's going on. Please tell me,  what zip code are you having trouble in? Does your device perform better in other areas?
VanetrisC_VZW
Revoe
VanetrisC,
  Thank you for your response.  Although the issue remains regardless of device physicality, my zip code is 14618 for the sake of discussion/troubleshooting.  All 4 devices have varying uses and utilization, but 3 of the 4 are connected to wifi almost 100% of the time when used.  The one that is not eats battery at the same or greater pace.
  Network connectivity has never been an issue as all devices have great reception to LTE and are in close proximity with full reception on wifi.  None have phone cases that affect temperature or reception to any perceiveable or measurable amount. This drain continues regardless of performance mode, radio status (LTE, wifi, NFC) and of course the issue is exacerbated with an increase of screen brightness (as expected).
  Please bear in mind that my complaint isn't simply poor battery life, but rather a substantial increase in battery consumption since this software update and the past one (also the 4th one back). Not the previous two, but the third update ago corrected this same complaint since 4 updates ago was the first I and my family really noticed the drain. The original Android 8.0 upgrade was the best as it brought the new functionality and a balanced battery.
  I know this is a lot of information, and I have much more than this to share, but I will await your response so I can supply you with relevant information to your assistance. Thank you again,
Matt
Revoe
Sorry to add more info, but I feel this is very relevant and key; with this increase battery consumption, we have noticed a proportionate increase in heat production and a serious decrease in application performance.  All apps are slower to open and feel "laggy", Google Maps seems to be the worst offender and now responds at about 1/10th the pace previously experienced.
Matt
