USB Problems and why does my phone read "Dialled" calls?
Sweetie1215
First off, I love my Samsung Fascinate and I anticipate the overdue Android 2.2 update (which is "rumored" to be avaiable Feb. 22) After the recent update, I noticed my phone will not connect to my PC and now takes longer to charge. I've contacted Samsung customer service and none of their suggestions solved the problems. Also I noticed while viewing my call log it reads, "dialled" calls. I'm wondering has my phone always read this and I'm just now seeing this or did it change after the update. Either way, it's embarrassing for words to be misspelled on such a nice phone.
Correct Answers
Re: USB Problems and why does my phone read "Dialled" calls?
PJNC284
Sr. Member
yeah, you can try getting the usb drivers from http://www.samsung.com/us/support/downloads/SCH-I500RKAVZW and clicking Software.  Latest version is on the bottom.  May want to try another usb port if that doesn't work.
10sEn
Novice
Odd that your phone won't connect to your PC.  Could you mention some details about the steps you've taken to do this?  It's difficult to help without more details.
If you're connecting via USB, I'm sure they've already mentioned that since the DI09 update, you now have to long press your phone's notification bar when the USB icon appears, slide the notification bar down, press the USB notification, and then select Mount on the popup.  If not, then that's what you need to do.
The fastest way to charge your phone while keeping your phone on is to turn off your screen and charge it using the wall charger.  You just don't get the same amount of power coming out of the computer USB port.  I usually charge it this way overnight, and I'm sure it's fully charged before I wake up.
mdram4x4
Leader
under call log hit the menu button>view by and make sure its all calls
try this to conenct to pc
menu>settings>applications>usb debuggin on
it worked for mine
PJNC284
Sr. Member
There are quite a few spelling errors in there courtesy of Samsung so it wouldn't surprise me.  The latest Froyo leak has EDF instead of DEF on the 3 key. lol
KellyW_VZW
Sr. Member
Thank you PJNC284, mdram4x4, and 10sEN for posting feedback and some troubleshooting steps. It's very much appreciated.
Sweetie1215, I sent you a Private Message, please review; and respond to the Private Message.
Thanks!
KellyW@VZW
Sweetie1215
I was instructed to try turning on the debugging feature. The USB icon will show up, I clicked it and it ask to mount or not. I click mount and nothing happens.
PJNC284
Sr. Member
If you go to My Computer, it doesn't show anything as removable storage?
Sweetie1215
Nope it just shows USB not recognized in a bubble in the lower right hand corner
mdram4x4
Leader
try getting the driver from samsungs website
what os is your pc?
PJNC284
Sr. Member
