Wh does my s20 plus say lte plus and not 4g lte?
Lincog
So I got a new of the s20  the unlocked version,  I have Verizon everything seems be workinv. But on the bar, on the far right to the battery it usually have 4g LTE, instead says lte plus, help?!?
Re: Wh does my s20 plus say lte plus and not 4g lte?
Tigerstep
Specialist - Level 3
You want help for the phone connecting to better LTE?
Ann154
Community Leader
Community Leader
The unlocked version of that phone is likely programed to connect to many different types of LTE from all of the carriers. How the LTE is displayed on the phone itself is different from carrier to carrier for the branded models. For example, AT&T phones will show LTE as just "LTE" on the phone and Verizon Wireless models show "4G LTE" on the screen. Since you have the unbranded model it might use the most commonly used wording/label across all the carriers for LTE.
The phone might also be connected to the Verizon Wireless 5G network which is technically not a true 5G network yet, but is instead more of a LTE+ network.
