calendar setting issue - please help
peeks2011
I have google calendar. In order to sync appointments that i entered into my fascinate i have to choose the correct calendar from the list on the phone. However, I didn't know this at first and there are plenty of appointments that won't sync because they are set as "my calendar". when I try to edit these it won't let me change this setting. Any suggestions on how I can do this? and is there a way to set all appointments at once instead of individually? I need to these to sync with my computer account. Thanks for the help
Re: calendar setting issue - please help
jjpslc
This is a known problem with the 2.1 software. The 2.2 Froyo update (if we ever see it) will supposedly fix it.
In the meantime, you are correct in noting you have to select the correct (gmail) calendar when creating an entry on the phone. If you forget, the phone won't let you later edit the calendar. You have to re-enter a new calendar item with the correct calendar.
gsp10
Basically You will never get it fixed then and you can put all the blame on verizon
