Receive up to $504 promo credit ($180 w/Welcome Unlimited, $360 w/ 5G Start, or $504 w/5G Do More, 5G Play More, 5G Get More or One Unlimited for iPhone plan (Welcome Unlimited and One Unlimited for iPhone plans can't be mixed w/other Unlimited plans; all lines on the account req'd on respective plans)) when you add a new smartphone line with your own 4G/5G smartphone on an eligible postpaid plan between 2/10/23 and 3/31/23. Promo credit applied over 36 months; promo credits end if eligibility requirements are no longer met.
Do you know how the Verizon Set Top Box is connected to the TV ?
Have you tried to change the TV Channel to 3 or 4 ?
Snowy picture is 1 of 3 issues:
1- Coax cable has been removed from either STB or TV (unlikely)
2- The "input" has been changed on your TV. Try scrolling thru your input options on your TV until you see your picture come back.
3- Your TV channel has been changed and needs to be put back onto channel 3. (sometimes ch 4)
