Receive up to $504 promo credit ($180 w/Welcome Unlimited, $360 w/ 5G Start, or $504 w/5G Do More, 5G Play More, 5G Get More or One Unlimited for iPhone plan (Welcome Unlimited and One Unlimited for iPhone plans can't be mixed w/other Unlimited plans; all lines on the account req'd on respective plans)) when you add a new smartphone line with your own 4G/5G smartphone on an eligible postpaid plan between 2/10/23 and 3/31/23. Promo credit applied over 36 months; promo credits end if eligibility requirements are no longer met.
I just added two new boxes to my home. Motorola 6416 DVR and Motorola 7100-P2. The 7100-P2 gets guide and vod service perfectly. The DVR however does not. I swapped the DVR to the other location and it still does not recieve an IP address. I had originally thought it was a MOCA communication issue but because the other box receives guide updates and vod works i ruled that out.
I rebooted my router serveral times and still nothing.
I current do not have time in my schedule for a tech to come. I was just curious if i could do anymore self diagnosing or repairs on my own.
Does a DVR box require a stronger signal strength to pull its guide vs a non dvr box? Thank you for your assitance.
@Tumo135 wrote:I just added two new boxes to my home. Motorola 6416 DVR and Motorola 7100-P2. The 7100-P2 gets guide and vod service perfectly. The DVR however does not. I swapped the DVR to the other location and it still does not recieve an IP address. I had originally thought it was a MOCA communication issue but because the other box receives guide updates and vod works i ruled that out.
You can try the diagnostic in the box and run the In home Agent. I would not have accepted a 6416 DVR because it does not support the new HD guide, and if you are having trouble with it, I would take it back. Unless that is what they shipped to you. I do not believe they are sending those out.At the minimum I would want the 7216 because it supports external storage expansion. Or the prefered 7232 which has to 500GB internal storage. If you went to the store to pick it up I would go back. But first use the contact us link I provided at the bottom. They can troubleshoot it and give you options. If it does not work at a location where another box works, it is the box. No tech visit should be required.
http://www22.verizon.com/Support/Residential/tv/fiostv/receivers/equipment+issues/top+questions.htm.
Or Visit for ideas.
http://www22.verizon.com/support/residential/tv.htm
Another option would be to contact Verizon, and have them do a reset of the box.
I'll give that a shot and report back. Thank you.
