Noisy power supply fan
ffrcoupe
Enthusiast - Level 3
I have a QIP7216 and the power supply fan gets noisy sometimes. It is definitely not the hard drive because when I pick up the STB and move it around the noise changes.
It’s mildly annoying at this point because I can disconnect the STB from the power, leave it off for a minute or two, plug it back it, and the noise goes away for a while.
Does anyone else have this issue?
Re: Noisy power supply fan
VZ_JoeD
Contributor - Level 1
Is your DVR well venthilated?  If it is overheating it may be the reaon the fan runs so high.  Are you still having this issue?
