I am waiting for replacement phone. Is there a way my incoming text can be forwarded to my gmail.com email?
dance_mom8
Hi. Is there a way I can forward incoming texts to my gmail or work email temporarily?
Re: I am waiting for replacement phone. Is there a way my incoming text can be forwarded to my gmail.com email?
Ann154
MVP MVP
MVP
You could look into using the Verizon integrated messaging instead.
What a great question! I'm sure you don't want to miss any important messages while waiting for your phone.
You can definitely try integrated messaging as Ann154 mentioned. It doesn't forward the messages, but at least you can stay in the loop.
http://vz.to/157NqCt
TamaraH_VZW
