Problem setting familybase data usage limits
iowalongs
I am having a problem setting FamilyBase data usage limits. I was able to set it successfully for my own phone, but when I try to set it for my son's phone it says Usage Allowances Update Failed.
His phone is powered off as the instructions say. Help?
Correct Answers
Re: Problem setting familybase data usage limits
zellerandy
Sr. Member
log out and log back in to your account and try again
zellerandy
Sr. Member
Thanks for trying the instructions, iowalongs. Were you able to try the suggestion from zellerandy to resolve the allowance update to go through? If not, try also clearing your browser's cache and temporary internet files or even a different browser to allow the update. Also, when logged into www.vzw.com/familybase as the account owner, go to the Profiles tab and make sure his line is set as a Child line. If not, select the Edit Parent/Child Roles link at the bottom.
JenniferH_VZW
Follow us on Twitter www.twitter.com/vzwsupport
iowalongs
Logging back out and then in again seemed to work. Thank you.
