What is pin # on router, where is location of it..That said should be 8 digit #...
What PIN number are you looking for? Would this be for connecting your PC to the Westell? If so, what you want to use is not a PIN number, since the Westell does not support that. What you want to do is use the WEP key provided at the bottom of the router. If none is present, you can find the Wireless key by visiting http://192.168.1.1/ , choosing the Wireless Settings page, and then locating your Wireless Security key under the Basic Wireless Setup. If you need a login, try the following:
admin/password
admin/password1
admin/admin
admin/admin1
My router seems to have locked me out. I cannot get into the settings using the IP address. Any thoughts on how I can get into my router settings?
@RedValley wrote:My router seems to have locked me out. I cannot get into the settings using the IP address. Any thoughts on how I can get into my router settings?
Reset the router to the Defaults.
I believe that is doneby pressing the reset switch/button as you turn off and turn on the power to the router.
