PROBLEM SOLVED! FIOS PHONE WON'T RING AT ALL, U GET VM OR PFL01 CODE CALL CAN'T BE COMPLETED!
MAYBESOMEDAY
Enthusiast - Level 3
MY FIOS TELEPHONE WOULD NOT RING AT ALL, THE CALL WENT DIRECTLY INTO VOICEMAIL, AND NO MESSAGES WOULD NOT SHOW UP IN CALL NOTIFICATION IN MY E-MAIL, ONLY THE CALLERS NUMBER!
THEN IT STOPPED GOING INTO VOICE MAIL, AND THEN WHEN U CALLED MY NUMBER, IT WOULD SAY:
"THIS CALL CAN NOT BE COMPLETED-PFL01"
WELL AFTER TECH SUPPORT WORKED ON IT, THEY FOUND IT WAS IN THE SWITCHES, WHICH IT WAS, AND WHAT IT WAS IS THE "CALL FORWARDING" WAS ON, TO A NUMBER I NO LONGER HAD, MY OLD CELL PHONE.
SO I FIGURED OUT HOW TO GET RID OF THE REPEATING SCHEDULE IT WAS ON, PERMANENTLY!!!
THIS STOPPED THE PROBLEM, AND NOW IT WORKS RIGHT!
THE VOICE MAIL IS NOW BACK ON, I ADJUSTED THE NUMBER OF RINGS, AND THE E-MAIL NOTIFICATION WORKS WITH THE AUDIO MESSAGE FROM THE CALLER!!  VIOLA !!
THANKS FOR ALL OF THE TIME AND TROUBLE, AND A WHOLE STRING OF EVENTS HAPPENED BECAUSE OF IT, TOO LONG TO GO INTO HERE!!  JUST SO VERIZON TECH SUPPORT IS WISE TO THIS ONE AND U KNOW NOW WHAT IT WAS !!  ITS A GREAT SYSTEM WHEN ITS WORKING RIGHT, BUT THERE ARE SO MANY CHOICES AND SETTINGS, ITS A WONDER IT WORKS AT ALL !!    THANKS TECH SUPPORT, {Edited for privacy}, BRANDON, FL.
ITS EASIER SAID, THEN DONE!!
