I am using my JetPack with my laptop, connected by a USB. It doesn't work remotely so I need to use the USB cord,.
I'd like to use the JetPack with my new HD7 but the USB connector is too large. Is there an adaptor I can use? WIll the Jetpack actually work with the HD7? What to do?
The tablet uses the wifi signal off the jetpack to get the internet signal. connect to the jetpack that way and not with the cord.
According to page 5 in the User Guide, No! The USB port is a power port, it is not a data port (see first paragraph on page 6). The HD7 has Wi-Fi and the Jetpack is a Wi-Fi access point. If you tell us what model Jetpack and what happens when you try to connect remotely we might be able to better assist.
