How Do I Fix My Droid Turbo's Power Button?
wzpt
-The only issue really is when it dies, it's painful to turn on, I have to sit for like 10 minutes to finally get it to work once.
-I've been using an otter box within the entire time.
-I've discovered a way to turn it on where you plug it into the computer to boot it but that's far too obnoxious.
-It's progressively gotten worse in the past 3 weeks, started out as not clicking but working every 2-3 tries, and so on and so forth to nothing at all
-I got the phone from Asurion as a replacement.
-It's a droid Turbo (1)
Labels (2)
Correct answers
Re: My droid turbo recently acquired a broken power button, it doesn't click like it used to.
Customer Service Rep
Hi wzpt,
I'm so sorry to learn of the issue with the damage of  your device. It's a real bummer, I've been there myself.
Since you mentioned that it's from Asurion, I would need to direct you back to Asurion, since the phone came from them. You can reach them directly at 888-881-2622.
ChristinaB_VZW
Hi wzpt,
ChristinaB_VZW
