Just got the update to Nougat for my Galaxy Note 5. If I enable maximum power savings mode, it is not possible to disable with out restarting the device. I've tried from the home screen and from settings. The same appears to be true for emergency mode.
have you rebooted??
Yes. That's the only way I can exit max power saving. Not fun. Makes max power saving pretty much useless.
do you have to use the max saving power setting, i chose not to & my batt usage is the same as before the update.
Don't have to, but nice to have. If there is no solution for this issue, I won't use.
That's a great feature on the Note 5. It should disable automatically once it is charged to a certain battery percentage. Have you attempted to plug it in and see if it disables?
JosephT_VZW
