***Announcement: Welcome to the new Verizon Community! We have merged our Wireless and Fios Communities to bring you the best place to discuss any Verizon product or service, along with all things tech! We have many new features to discuss with you in the coming weeks, but first we want to make sure that all of you who have been active on either of our communities before are able to log in! For many of you, we have been able to merge your Wireless and Fios community accounts so all of your Community contributions are all in one place. If you were active in both communities and you previously used the same My Verizon account to log into both, you’re all set! You will be able to use those same credentials to access the new Community. If one of those accounts was with My Verizon and the other was a Community Member Only account, please use your My Verizon account to log in. Please note that we were only able to merge those accounts that were attributed to the same email address. If you only had one account on either Community, you can log into that account exactly as you have before. For some of our Fios Community members, you may have an issue logging in. If you had an account on the Fios Community and you’re having login issues, please use the Community Member Only login page and use the “Forgot my info” link to reset your password. Once you complete this, you should be able to log in normally. If you continue to have any further issues logging in, please email us at verizon.community.team@verizon.com and we’ll assist you to get you back in the Community! Keep an eye on the Community announcements - we can’t wait to show you what’s in store. The Verizon Community Team
update 4DRB1 battery problems
Baylorr
Enthusiast
Since installing the latest update G920VVRS4DRB1 battery service has gone down hill.  Is there a fix for this?
Re: update 4DRB1 battery problems
BAYREI98,
Sorry to hear about trouble with your device after installing the latest update. How long ago did you complete the update, and is the issue still occurring? Often after completing an update, it can take about a week or so for all of the applications to be optimized, and sometimes longer for app developers to push compatability updates if necessary. If the issue is still occurring, please have a look at your phone's battery information in settings to see if it shows any particular application or service using more power than normal. We'll be standing by.
EricW_VZW
BRUENG2
Enthusiast
When is the software patch going to be available? Charging my phone every 3 hours in not acceptable not practical.
BRUENG2
Enthusiast
I was in Verizon store yesterday. They know the update screwed up all S6 and S7. Don't have a fix. Will eventually release a patch. God only knows when.
BRUENG2, software updates are meant to enhance the phone. So sorry to hear it is causing problems. Help is here. With any software update, it is always recommended completing a factory data reset on the phone to ensure all 3rd party applications are compatible with the new software. If the 3rd party applications are not compatible, it can cause the device issues as these applications work harder, causing the battery to drain. Please advise if this step has been completed. Click here for the steps for resetting the device. http://spr.ly/6584DTHxm
NatashaA_VZW
BRUENG2
Enthusiast
I have had dozens of updates and at to time have I had to rest my phone. I visited a Verizon store and they all were aware of this issue.
So why would you tell me this when it is clearly not the correct answer?.
kathy65793
Master
Have you ever cleared the cache partition on the phone? After shutting the phone off hold Volume up-power-home. Use the volume down key to go to clear cache partition then tap the power key then use the volume down to say yes and the power key again. Then just reboot the phone like normal This is one of the most common problems after an update. Doing this will not change any of the phone settings. It just clears out a lot of old files that may be in conflict with the new ones
BRUENG2
Enthusiast
Yes I exactly that procedure prior to contacting you. What i was told was that the update to the s6 and s7 phones tries to bring them up to s8 as far as software.  This causes the battery to die from attempting this.
Hard to believe a commercial store knows this but Verizon doesn't.
Not your fault just stating facts from a frustrated consumer who has 3 lines
We'd like to apologize for the confusion regarding your update and different information being given, BRUENG2. It's important your device battery is working as it should. Let's take a closer look into this. Samsung has not advised that this is a known issue with the update at this time. Samsung does advise that after a software update, the device goes through an application optimization which occurs in the background. This is a necessary part of the update and you will experience battery drain during this time frame. This should correct itself within a few days. If you continue to have trouble, we would further troubleshoot. Please ensure all apps are up to date. What is the device used for daily? How many hours does the battery last before it will power off from battery drain? Has there been any damage to the phone?
DanielleR_VZW
McC007
Enthusiast
Yep, same problem here.
To answer the support queries:
1. This has happened since the update was pushed, roughly a week ago.  In fact, it seems to be getting worse.
2. Battery longevity before update - minimum 48 hours
3. Battery longevity after update - roughly 8 hours
Checking the Battery usage under Settings, Android OS typically uses nearly 40%.  To put it in perspective, my phone has been doing nothing since I started typing this, and in the last 10 minutes battery has dropped 5%.
For what it is worth, this is the second battery destroying update I've had in the last 3 months.  Before the one in December, I could get 3-4 days.  After the December update - about 6 hours.  Ended up driving 45 minutes to the nearest Samsung support keyosk, in a Best Buy, where they did a hard refresh.  That "improved" the usage to the 48 hour mark.
And don't get me started on how the latest updates have screwed up wireless connectivity.  On my home wireless, pre-Dec update, no problems.  Since that update, I have constant problems in that the connection drops all the time, and I have to reconnect every 30 minutes or so.  I finally gave up and turned off wireless unless I need it - which actually helped the battery usage substantially.
