Noticing a long lag between pushing button on remote control and the cable box responding more often. Can see the red light on box blink that it received the command, but takes 5+ seconds for numbers to come up on screen to change channels.
Also when it displays the “More Like This” section on items played from dvr will take 10+ to load screen.
Anyone else have this happen/fixed this issue?
New ONT Dec 2021, Gigabit connection, Newest router Dec 2021.
Happened before and after mew installation.
I find that you have to reboot the stbs every few weeks.
They tend to speed up after the reboot.
