Can I connect my cable box to my smart tv wirelessly w
Lilybethsox
Re: Can I connect my cable box to my smart tv wirelessly w
eljefe2
Master - Level 1
If you have a Verizon router and it's providing wifi coverage to the room where your smart TV is located, and if your smart TV has wifi capability, then yes, you should be able to connect the smart TV wirelessly.
However, what you might consider, rather than using wifi, is using an Actiontec adapter, ECB2500C:
http://www.actiontec.com/251.html
That adapter will let you easily connect your smart TV via Ethernet cable.  (Assuming, of course, that your TV has an Ethernet port for its smart TV features.)    You may find that the hardwired connection is more reliable and less subject to interference than is wifi.
