Has anyone had success linking the Verizon FiOS remote with the Sony Blu-ray model BDP-S350? None of the codes work, neither does the fast-forward technique. Verizon says they likely don't have the code, because there are so many models. Has anyone found one that will work?
Search that remote on Google and there is a link to a PDF of the instructions with all the codes.
None of those codes work.
Not all devices will program to the Verizon remote. Keep in mind it is a cheap remote. If you want a true universal remote you can check out logitech remotes. They have a few models under a hundred dollars.
