My dvd player is connected to the TV. However, when the TV is on, the DVD disc doesn't show on the screen. Pressing the TV Input (A/V) button on the remote does not change the HD setting to A/V setting. It does nothing. After turning the TV set off completely by remote and turning it on manually on the actual set, I cannot change channels or do anything; the screen says I must turn on FIOS to get TV reception. How do I get my DVD player to show on the screen thru FIOS? The player is connected to the TV and the TV is connected to FIOS.
The FiOS remote does not always operate all functions of a TV.
Use the TV's remote to change inputs to show dvd player.
Got it ! Thanks ! It's a little convoluted with the two remote and getting to the right screens but it works.
