FIOS remote for cable box needs to be replaced
@cards85 wrote:FIOS remote for cable box needs to be replaced
Check here:
Main Menu > Customer Support > Top Support Tools > Replace Fios Remote > Replace Fios Remote
A replacement remote control can be ordered from Verizon.
Check here:
