I have a new FiOS set top box and wireless remote, paired to a Vizio E70uD3 TV. The FiOS remote “says” it is connected....and mostly it is. It turns the TV on and off. The mute works. The volume and channel buttons work. The input buttons work.
However, the up/down arrows don’t work (when in apps like Netflix), and the menu and stop/start buttons don’e work either. Has anyone found a solution to this?
JPB
