Guide doesn’t work
Steve710
The guide doesn’t work. It says no program name. It’s only on 1 box. Suggestions?
Re: Guide doesn’t work
Edg1
Super User
Super User
Could be the box or cabling if only on one box. Try taking a good box from another room and see if it works there. If it does then that box is bad. If the good box also doesn’t work then it is probably cabling.
Steve710
I unplugged it for 10 min and it worked when I plugged it back in. Thx for replying!
Edg1
Super User
Super User
Your welcome
