You used ot be able to hit the Info button twice and get detailed info like air date and cast. Now you get no further info than when you hit it once, which is a brief description of plot.
Even hitting Info while in the guide doesn't help.
Also, you can no longer select a recorded program in the DVR, hit OK, and be given the choice to Delete or Play.
Now to Delete you have to hit the C button.
What model STB do you have?
Works fine for me on VMS1100 and IPC1100.
Have you tried rebooting STB?
I have the motorola qip7232 2.
I'll try rebooting.
This thread will be locked in order to keep discussions current. If you have the same or a similar question/issue we invite you to start a new thread on the topic.
