I need help programming FiOS remote
FrancineEisner
My Element TV needs to be turned on using both FiOS remote and Element remote. So inconvenient. Want to only use FiOS remote. How?
Re: I need help programming FiOS remote
clem21
MVP MVP
MVP
Which Fios box do you have? If a Fios 1, you go to the menu, settings>Fios Voice remote>Auto setup. Hopefully the remote will find your TV and you'll be all set.
clem21
MVP MVP
MVP
Sorry, forgot to add this if you need help with the remote:
https://www.verizon.com/support/consumer/tv/equipment/remote-control
