Hi
My fios box is connected to a new LG TV and an older Marantz SR880 receiver (HDMI cable from the fios box to the TV, then an optical cable out from the TV to the optical port on the receiver). All of this works fine. Went through the automatic process of connecting the fios remote, and got the message the the remote is successfully connected to the LG TV and the Marantz receiver. But the volume buttons don't change the volume on the receiver. But I think it is paired properly, because the Mute button does work. Any thoughts?
Thanks
Ed
Never mind.....got it to work
I need the solution and can’t find it !
This post says there is a solution, but I can’t find it. Help!
@Ljr1 wrote:This post says there is a solution, but I can’t find it. Help!
Go to Menu > Settings > Voice control > Fios TV Voice Remote > Program Voice Remote > Manual Setup
